I'd say the full float Nissan H260 (manufactured by Hitachi) out of a Patrol ute would give a Dana 60 a damn good run for its money.
Dana 60 Carnage
- catalystracing
Re: Dana 60 Carnage
Looks as if the rust mark around the top of the break may indicate a previous crack.
Re: Dana 60 Carnage
Pushing those diffs to hard. There seems to be a couple of common weak points, I wonder if that style design is naturally weak when compared the fully welded diff structure with the swivel knuckles?
Re: Dana 60 Carnage
With the abuse they are given the diffs do bloody well.
Re: Dana 60 Carnage
Theres no off the shelf axle available here that even comes close.
Re: Dana 60 Carnage
Really? What about my Vitara alloy diff? Its so tough that it takes two people looking at it to break it...
Just pushing them too hard by the sound of it.
Re: Dana 60 Carnage
The Vitara front diff is definately right up there.
Actually we do have a Dana 60 available here, just not a steering axle.
Take a Salisbury from an old Land Rover 109. Remove the axles and side gears and throw them in the bin. Fit 30 spline or greater side gears which are an off the shelf part.. custom axles... voila, 4-pin Dana 60. Pretty much unlimited locker/gearing options as all the internals are D60.
