I have been fumbling around trying to get a 16v suzuki motor running on a megasquirt ecu for the past two odd months . The first big err was not looking at the wiring diagram properly and noticing the ecu controled the ignition . Hmm , slight rewire and reprogram of the ecu ( it now has launch control , nitris and water injection and a bunch of other stiff a suzuki does not need to know about ) and all was sorted .
A few glitches along the way , battery not the best so once the volts got through the jumper leads to the engine it was lacking , hence no spark .
Anyway it finally burst into life this evening and about bloody time too . Now to find an exhaust , figure out whats up with the oil pressure light and I can start tuning it a bit more
The first rip down the street will be a good one .
Chris
