Toyota Landcruiser Axle and CV Options For Sale
From lockers to air deflaters, if it has to do with wheels tires or axles, you can find it in here.
Moderator: Vendors
4wdstuff
Post by 4wdstuff »
Hi,
If you are looking for Landcruiser CV and Axle Options have a look below.
Trail-Gear Toyota Front 27 Spline 4340 Chromoly Birfields (CV's) $140 each
Longfield 27 Spline CV's USA Made $300 each
FJ40 Longfield 30 Spline SuperSet USA Made $1050 . NONE left.
Trail Gear FJ40 Longfield 30 Spline SuperSets Axles and CV's $850 the Trail Gear ones I believe are not made in the US.
Trail Gear FJ40 Longfield 30 Spline SuperSets Axles and CV's with Hub Gears or Creeper Drive Flange Kit $1000 Trail Gear ones I believe are not made in the US.
FJ40 Longfield 30 Spline SuperSet with long spline for cable locker USA Made $1125. NONE left.
FJ60 Longfield 30 Spline SuperSet with long spline for cable locker USA Made $1150. Only 2 left.
Trail Gear FJ60 Longfield 30 Spline SuperSets Axles and CV's $850 the Trail Gear ones I believe are not made in the US.
Trail Gear FJ60 Longfield 30 Spline SuperSets Axles and CV's with Hub Gears or Creeper Drive Flange Kit $1000 Trail Gear ones I believe are not made in the US.
FJ70 this can use the same axles and CV's as the FJ40 ones, see above.
LJ7? and KZJ7? Longfield 30 Spline SuperSet USA Made $1250 . Only 2 left.
The earlier models had a smaller axle seal than the later ones, if you have the later model you need to get an earlier seal. The toyota seal no is 90310-35010. Also have a look at http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=31422&hilit=longfield
Longfield Hub Gears to go in your AISIN hubs, $200 a pair.
Longfield Drive Flange Kit w/Dowel Pins, Drill Bit and Dust Shield $275 for a pair
Toyota Creeper Drive Flange Kit w/Dowel Pins, Drill Bit and Dust Shield $210 for a pair
Just need to add on post.
PM me if interested
Cheers Tim
http://www.4wdstuff.co.nz
4wdstuff
Re: Toyota Landcruiser Axle and CV Options For Sale
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
Return to “Axles Tyres and Wheels”
