hilux rev counter not working
My rev counter has never worked since ive owned the truck. I want to get it to work its a 1989 ln106 3l. I am aware of the pick up from the diesel pump. but my pump only has the one wire for the solinoid. Is there something else that sends it?
Re: hilux rev counter not working
My 1989 LN106 3L had the rev counter stop working, it was caused by dry solders on the back of the dash.
I got it fixed by having an auto electrician resolder the connections on the back of the dash.
Here is a link for the feed to the rev counter
http://www.4wdaction.com.au/forum/viewt ... 2&t=144907
Cheers nzlux im goin to look behind speedo cluster this weekend. I looked at the link the fuel pump has the twin wire feed where as mine has the one wire for the fuel cut solenoid no wire for tacho. Ive read somthing about some of these ln106 with cable speedo hav this problem when a hiace or another type pump has been fitted
