TD27 Boost Compensator
Posted: Mon Apr 28, 2014 1:10 am
by travis2ninja
How hard is it to change the injector pump from a Non Turbo to a Turbo Engine.
Or can i just put the boost compensator onto the non turbo injector pump?
How hard would that be?
Re: TD27 Boost Compensator
Posted: Mon Apr 28, 2014 7:41 am
by ChurchurDan
Pumps are not to hard to change. I have never taken the compensator off but I imagine it would be easier to change than the pump, Also non turbo pumps have a higher rev limit spring in them so will keep fuelling to higher revs.
Just mark how everything fits on and keep it all clean.
Posted: Tue Apr 29, 2014 12:17 am
by travis2ninja
So to switch pumps over, the engine has to be on tdc on the 1st piston, and just line the "zzz" up?
Posted: Tue Apr 29, 2014 7:32 am
by ChurchurDan
I just line the zzz up
Posted: Tue Apr 29, 2014 4:45 pm
by travis2ninja
When I take the Injector pump off the other engine. Does that also need to be on tdc. And the 'zzz' lined up? Then lock it in place?
Posted: Tue Apr 29, 2014 5:38 pm
by ChurchurDan
Not necessary but they are hard to turn to get into the right spot so it can make life easier
