AS-450 Winch fitting.
Posted: Wed Apr 30, 2014 2:56 pm
by Daggers
Hey guys,
Recently picked up an AS-450 winch from a mate for a good price.
What do I require to fit this to my 1998 LN106 Hilux?
Re: AS-450 Winch fitting.
Posted: Wed Apr 30, 2014 3:52 pm
by mudlva
bit of 3mm plate of the right length, bent at the right places, couple of holes, sorted
Posted: Wed Apr 30, 2014 4:55 pm
by Daggers
:lol: Yeah I figured as much. Was wondering if anyone had done this though? I'm pretty sure it has the original surf winch mounting plate with it. I'll post some pictures tonight.
Posted: Wed Apr 30, 2014 5:14 pm
by mudlva
pics I found by using google
Posted: Wed Apr 30, 2014 8:42 pm
by Daggers
Posted: Wed Apr 30, 2014 10:01 pm
by nismo26
Whats it rated to? looks pretty small.
Posted: Wed Apr 30, 2014 10:11 pm
by mudlva
Kricky there fella you got all the bits ready to go.
Rip ya bumper off and bolt it on
Stop asking question on fitting and start posting pics of it hauling ya truck out of boggs :D
Good little winches them
Posted: Thu May 01, 2014 7:20 am
by Daggers
1500 kg. Considering the Hilus has a vin plate weight of like 900kg. It should be plenty for most things.
Do you think it will just bolt on? I have to pick it up in a couple of weeks. Then we'll see if it is a case of bolting on.
Posted: Thu May 01, 2014 7:44 am
by mudlva
Stop asking question on fitting and start posting pics of it hauling ya truck out of boggs :D [/quote]
Do you think it will just bolt on? I have to pick it up in a couple of weeks. Then we'll see if it is a case of bolting on.[/quote]
With the use of a drill it may bolt on :?:
Still you started with what do i use? Then precede to say it come with the complete mounting bracket!
Imho i would use that and react if things are completely differant.
But a chassis is a chassis and both made of steel
Posted: Thu May 01, 2014 10:41 am
by Daggers
Yeah. Thanks man.
I'll post more photos when I get a hold of the winch.
Posted: Thu May 01, 2014 12:03 pm
by crazyclark31
Can assure you that your truck weighs way more than that. Then add the stuck factor and you'll find that winch is a bit light. But it will help.
Just be prepared to double/triple purchase with it.
I'd take off the bumper etc from your truck and try and fit it as is. Then just adapt it as needed to be able to bolt on. Make sure you use ht bolts when fitting. You probably find it's just a case of drilling a couple of holes to get it to fit.
Posted: Thu May 01, 2014 12:51 pm
by Daggers
Thanks man. I'll post pictures and information when I get a hold of it.
Posted: Fri May 02, 2014 9:37 am
by zukmeista
Pretty sure that plate that the winch mounts to is fitted onto a nudge bar type thing like in the pic mudlva posted, a mate has one lying around (nudge bar bit)
Posted: Fri May 02, 2014 1:04 pm
by derk
Daggers wrote: Considering the Hilus has a vin plate weight of like 900kg.
the 900kg tag your looking at will probably be the load carrying capacity the truck will weigh around 1500kg :D
Posted: Fri May 02, 2014 2:30 pm
by Daggers
Whoops. My newb is showing.
