Hi, as per title have got a number of options for Toyota.
LOCKRIGHT Mechanical Lockers
NOTE My understanding is that Lockright are NO longer made in the USA.
I have got both USA made ones and others that may not have been made in the USA. See below
MADE IN USA
Lockright RG1610 Hilux 2 Spider $575 incl freight NONE LEFT
Lockright RG1620 Hilux 4 Spider $400 incl freight
Lockright RG1630 Landcruiser 2 Spider $500 incl freight
MAY NOT BE MADE IN USA
Lockright RG1610 Hilux 2 Spider $400 incl freight
Lockright RG1620 Hilux 4 Spider $375 incl freight
Lockright RG1611 Hilux/Surf IFS $525 incl freight NONE LEFT
Lockright RG1630 Landcruiser 2 Spider $475 incl freight
SPARTAN Mechanical Lockers
They are basically the same design as the Lockrights
TDI-SL4 Spartan Locker for Toyota 8" 4cyl 2 spider $425 incl post
TDI-SL6 Spartan Toyota V6 Differential 4 spider $375 incl post
TDI-SL7.5 Spartan Locker, 7.5" Toyota Differentials $425
TDI-9.5-SL Spartan Locker for Toyota 9.5" Landcruiser $450
Also have some pin and spring kits for $35 incl post
ARB Air Lockers
RD132 to fit the 8" Hilux, Surf, LJ7? and High Pinion diffs $1400 plus post
RD142 to fit the 9.5" FJ landcruiser and 80 Series rear diffs $1400 each plus post.
Have also got some of the small ARB compressors for $150 if you buy an air locker at the same time. Only got 2 of these.
YUKON Zip Air Locker Similar to ARB.
To fit the 8" Hilux, Surf, LJ7? and High Pinion diffs.
Can do for $1150 plus post for the V6 housings
and
Can do for $1250 incl post for the 4 cyl housings as you need new side bearings.
EATON True Trac Limited Slip Toyota 8" V6 $600 plus post
PM me if interested
Tim
Toyota Diff Lock Options
Moderator: Vendors
Re: Toyota Diff Lock Options
What comes with the YUKON Zip Air Locker ????
Same as the ARB, locker, solenoid, switch and hose
Tim
Tim
Can you ring me at some stage 0272012916 Greg
poor little suzuki
Bump
See first post
Have reduced the prices for ORE readers
PM me if interested
Tim
See first post
PM me if interested
Tim
Can you supply an RD90, for a Toyota 7.5 inch front diff?
