Wanted D21 steering damper kit
hi guys im after a steering damper kit, (like the one below) dose any one know anyone in nz that sells these or could fab something up?
https://www.4x4parts.com/nissan/pathfin ... p-224.html
OR
http://www.summitracing.com/int/search/ ... pathfinder
just the brackets
http://www.autopartswarehouse.com/shop_ ... inder.html
Cheers Pete
OR
just the brackets
Cheers Pete
Re: Wanted D21 steering damper kit
I Pete,
My pathfinder has this standard.The draglink has the attachment cast into it, and the other end has a post type of thing attached to near the steering idler.
Maybe you could get these off a pathfinder or 4x4 Nav. (D21)
I recently replaced the 23 y/old Nissan one with a Munroe. Feels the same tho
We do the tough dog Rtc for $225 inc gst ,
I have a centre link here, brand new, with the steering damper bracket on it. It is for the pre 92 models I think (has the 13-15mm taper) Camelot TR4680
As for the chassis pin, you can get one from Nissan, they get them in x Japan, that's where I got mine from.
Ph 0212078472
Ph 0212078472
Thanks guys
Nissan no longer have any damper pins in nz.....
and thanks for the offer of the centre link but i only replaced not do long ago and i have a 2wd centerlink
kiwiinoz : did you drive without? if so what did it feel like? Also "nav4x4 and pathfinder" are they members on this site?
trundles : dose your rtc have a bracket to connect it to the center link?
cheers pete
cheers pete
Nav4x4 = Navara 4X4 truck
Pathfinder = Nissan 4X4
Both trucks, not members on here.
Ph 0212078472
Ph 0212078472
Ha ha ha ha come on guys that was a easy mistake to make......
anyway I have been to a few wreckers and no models seem to have them..
just contacted the main wrecker I deal with to see if he can find any just have to wait and see now, im quite interested in a return to centre damper do you have anymore details on it ?
I have a parts truck out the back I will go have a look I think its got what you wont.
cheers tatnz, That would be great I have private messaged you
cheers pete
cheers pete
still having trouble with finding one of these..... anyone ?
I can take mine off and trace round it and give you the size and length of bolts ect. Then get a piece of say 10mm flat drill the holes and weld a bolt to the end then go to bnt and get the damper mine was about $90 for a Monroe
poor mans fix
Was yours fitted from factory or did you fit it?
If so what difference did it make and what kind of mods do you have ?
cheers pete
cheers pete
