GU airbags / td42t rocker gear
Posted: Mon May 12, 2014 5:08 am
by slidenyo
I got myself a 97 gu safari factory td42 turbo auto,
noob questions as this is the newest 4wd that I've owned.
airbags and 4wds are there any precautions that must be taken to ensure they don't go off if I have a bump with something?
are airbag compliant bullbars just bars with mounting points for the factory sensors?
also I have heard that the factory rocker gear can need refacing?
I have a stem seal floating so will investigate that this week and get my feeler gauges out to look at the source of my tapping....
any experience or advice would be greatly appreciated
cheers Jase
Re: GU airbags / td42t rocker gear
Posted: Mon May 12, 2014 6:52 am
by bob_or_jim
Im not sure about all vehicles but the ones i have delt with dont so much as have sensors up the front but 1 usually mounted towards the trans tunnel under the radio area (in the cabin).
The air bag compliant bars have crumple zones in them to allow the bar to deform and send the normal decealerartion forces to the sensors during a crash. This is important as this changes the timing of the deployment of the bag......too soon and its half flat when your face makes it there for a kiss, too late and your in for a mighty punch in the face as you will be right over the wheel/dash when it deploys. Basically putting it they wont go off unless you need it, in which case you will be happy you had them. Hope that helps a little.
Posted: Mon May 12, 2014 7:03 am
by lax2wlg
slidenyo wrote:I got myself a 97 gu safari factory td42 turbo auto,
You mean Dad got you a 97 GU Safari factory td42 turbo auto.
Yeah, it sure sucks to have your thread bombed, don't it?
Posted: Mon May 12, 2014 4:26 pm
by bob_or_jim
lax2wlg wrote:slidenyo wrote:I got myself a 97 gu safari factory td42 turbo auto,
Cock!
Posted: Mon May 12, 2014 4:55 pm
by Crash bandicoot
the airbag compatible bullbars have rectangular crush tubes on the mounts between the bar and the chassi. when being pulled i.e. winching snatching towing another vehicle backwards they are just as strong as conventional steel mountings. when excessive force goes the other way they "crush" absorbing the impact.
I say excessive as a normal knock bang bash at low speed off roading wont effect them, we a talking the massive G forces involved in head on collisions.
All of nissan's airbag systems are triggered by the G force sensor under the center console between the two front seats.
In my case since ARB don't make a bar for the facelift R20 I ended up removing the airbag system and swapping out hte steering wheel for one from a base model D22 nissan navara
building your own bar or retrofitting another to a previously airbag equipped vehicle will need certification, so do it along with other mods like suspension etc.
Posted: Mon May 12, 2014 5:51 pm
by slidenyo
Thanks crash that is exactly the info I needed. as I planned on buying a front bar then adding my own sliders and rear bar
Posted: Mon May 12, 2014 6:37 pm
by TJ
Crash bandicoot wrote:In my case since ARB don't make a bar for the facelift R20 I ended up removing the airbag system and swapping out hte steering wheel for one from a base model D22 nissan navara
Not all airbag compatible ARBs for all makes necessarily have crush cans. Depends on the front end chassis for particular makes and models.
Also, I understand removing an airbag needs certification and can only be done on a vehicle older than 14 years.
Posted: Mon May 12, 2014 6:40 pm
by Crash bandicoot
TJ wrote:Crash bandicoot wrote:In my case since ARB don't make a bar for the facelift R20 I ended up removing the airbag system and swapping out hte steering wheel for one from a base model D22 nissan navara
good point, mine is a 98 so probably why it was never mentioned. something else to take into consideration.
Posted: Mon May 12, 2014 6:55 pm
by bob_or_jim
I have removed the air bags from my surf (1996) as when I fitted the SAS I ended up welding the crush dimples on the chassis so they required removing for cert. If your adding granddad bars that go over the front wheel arch you need to make some sort of slider that wont prevent the bull bar from moving back........they joys on newer 4x4's huh
Posted: Mon May 12, 2014 8:23 pm
by Trundle
We stock rocker shafts $300 inc gst , reface rockers 150 inc
Posted: Tue May 13, 2014 4:01 am
by slidenyo
cheers chap i'll have a gander under the tappet cover and see,
what I need.
where in taranaki are you guys?
Posted: Tue May 13, 2014 5:02 am
by lax2wlg
I was just jizzing around, slidenyo Jase works hard for his own toys. Glad you finally found a decent GU.
Must be time for another smilie.
Posted: Tue May 13, 2014 7:00 pm
by slidenyo
cheers chap its only reason I get up at 4 in the morning to head off to shifts or work through the night to finish them.
Posted: Tue May 13, 2014 7:23 pm
by Trundle
slidenyo wrote:cheers chap i'll have a gander under the tappet cover and see,
what I need.
We are in Oakura ,
the rocker shaft wears worst at the back of the shaft , Also the tappets wear where the pad contacts the valve ,
Posted: Tue May 13, 2014 8:46 pm
by slidenyo
whats the factory tolerance ?
i'll record what I have with the feeler gauges.
Posted: Wed May 14, 2014 10:34 pm
by Trundle
.3 but you need to remove the rocker shaft to inspect if they are recessed or not , also need to remove the rear rocker of the shaft to inspect the shaft ,
Trundle
Posted: Fri May 16, 2014 9:04 pm
by y60 safari driver
Trundle wrote:We stock rocker shafts $300 inc gst , reface rockers 150 inc
is that $150 t get all 6 done or is that per rocker? about to go down this line in nelson just getting an idea on prices. cheers
