lsd for the danas
Fubu
lsd for the danas
Post by Fubu »
Whats a good lsd or who would have a factory lsd for the dana 35?. Also is there such thng as a front lsd? Or is a locker the only way.
TJ
Re: lsd for the danas
Post by TJ »
I wouldn't spend any more money on a Dana 35c necessarily. LSDs can be had for both Dana 30 and 35c.
Can you be specific which year and model of XJ you have.
Going by 97 XJ, here is an option for the front D30:
http://www.quadratec.com/products/16104_102.htm
For D35c: http://www.quadratec.com/products/16104_003.htm
Have a look here: http://www.quadratec.com/category/Jeep+Lockers/55/index.htm
Fubu
Post by Fubu »
Yea I know they're not worth spending big bucks on but if I could pick up a factory one shouldnt cost a kings ransom. While were on the topic whats the easiest option for complete swap out. Id prefer a straight bolt in option but have access to an unloved exploder so may be able to rape that for its rear end.
Fubu
Post by Fubu »
Sorry its a 95 was the diesel model what ever that is. Has a 2000 4ltr petrol in it.
yeti
Bruiser
Post by yeti »
v8 tj...luvs the gas......
TJ
Post by TJ »
What rear end is on that explorer? I don't experience with it from Explorer into XJ. LSDs, Powertrax for open diffs should be relatively easy to put in. If all explods, then upgrade the rear end? Upto 32/33" tyres are not as detrimental as 35" tyres are on Dana 35c. The biggest problem is when the axle breaks, there is nothing holding it in. Any axle can break, but Dana 44 stays in place and can be driven (most of the times).
Fubu
Post by Fubu »
Only running 31s at the moment was going to go to 32s. I dont intend on any massive missions but an lsd would make it alot more capable.
TJ
Post by TJ »
Fubu
Post by Fubu »
Oh and would a steering damper make it a bit nicer on the road?
TJ
Post by TJ »
Fubu wrote:Only running 31s at the moment was going to go to 32s. I dont intend on any massive missions but an lsd would make it alot more capable.
Try driving the way it is for a few trips and see how it goes. Then decide if you need LSD or you can wait for lockers (once budget builds).
Fubu
Post by Fubu »
Thanks for the help dude. Yea im hoping a new set of tyres will help it out for now.
yeti
Bruiser
Post by yeti »
Return to “Jeep”
