I have decided to sell my trusty surf and am wondering what price to put on it? It is a kzn130 auto has only done 156000ks is body lifted on near new 33s and steelies custom made bullbar with winch spottys roof racks and basket external tranny cooler water temp and boost gauges sounds tints custom rear storage that folds into a bed body is good but has the typical clear coat peel on passengers door
Cheers mike
Also what are some things to look out for in a Yn61 surf with a 3.8 commy motor?
whats a kzn130 with a few mods worth?
Re: whats a kzn130 with a few mods worth?
Would guess at around $9k if it is tidyish, auto isn't worth as much as manual. Is the bodylift certed? Pics would give a better idea of condition so easier to guess value. Why the change, diesel would be cheaper to run than commonwhore and the truck you have has low k's and newer?
Yea it is newer and maybe cheaper but its only a weekend hack so would prob end up about the same and would be a bit better off road?
Probably not much difference offroad, both are IFS, 130 has coil rear 61 has leaf. I guess you might be less concerned about beating up the older one offroad.
The 1 im lookn at has a solid frount end so i guess its been converted or its not a yn61?
From what I understand the 60 is solid front and around 1984-1985 the 61 is IFS. Is it listed on trademe?
Yep listing number is 726666187
usually about the same as a kzn130 without any mods depending what's been done and how its been done can so also could be worth a bit less than a kzn130 without any mods, clean, low km's, unmolested trucks are the ones you get the best money for
- tomsoffroad
- Flopsie
zukmeista wrote:From what I understand the 60 is solid front and around 1984-1985 the 61 is IFS. Is it listed on trademe?
Your right ln/yn60 is the solid axle. 84-mid 85
Wild_South
Got photos mate?
1997 Toyota Surf KZN185 Intercooled, Silver/Grey, 2" Suspension Lift, 285/75/r16 Hercules Terra Trac D/T, 16x8 ROH Black Track Steelies, Roof Cage, 42" LED Light Bar, Limb Risers, Snorkel, Auber Gauges, Thicker Core Radiator, MCC Winch Bar
