17/18th may
Crash bandicoot
17/18th may
Post by Crash bandicoot »
Well the mechanical injector pump mod and T/C lockup works well.... Got a speeding ticket..with a trailer on...going uphill. :roll:
andy3542
Re: 17/18th may
Post by andy3542 »
Put the Land Rovers rego on hold for a 3rd year... :x :oops:
Offroad Addiction TV
Mattman
Re: 17/18th may
Post by Mattman »
Did front wheel bearings in my truck. Inners were rooted. Had to cut the bearing off the passenger side.
Shrapa
Re: 17/18th may
Post by Shrapa »
I had the privilege of having someone modify my truck for me.
Now I have no cd player + a smashed rear passenger window. :roll:
Got to love Auckland..
Side note: If anyone has a left rear quarter panel window for a 60 series landcruiser...
"Keep the shinny side up"
lax2wlg
Re: 17/18th may
Post by lax2wlg »
Having problems with breaking Warn hub bolts, It seems they back out a thread or two then shear. Real PITA continually having to EZ-Out broken studs.
So replaced them with 10.9 hexagonal cap screws. They have a slightly tapered shank like the factory Nissan bolts.
Also its WOF season so I sprayed the underside with used diesel oil. Works waaaay better than I thought it would. It looks real primo underneath.
hamboy
Re: 17/18th may
Post by hamboy »
lax2wlg wrote:Having problems with breaking Warn hub bolts, It seems they back out a thread or two then shear. Real PITA continually having to EZ-Out broken studs.
Its a Nissan thing, I've broken 3 so far
Crash bandicoot
Re: 17/18th may
must be doing it wrong. :mrgreen: double edged sword use lock tight cant get em out, don't use lock tight they snap but easier to get out.
derk
Re: 17/18th may
Post by derk »
warn hubs have a habit of coming loose and flogging out, are their any aisin hubs that fit those things the tapered collets keep them tighter and the're a stronger hub :D , are all the dowels still in the hub and not loose or flogged out
Crash bandicoot
Re: 17/18th may
I have same issue, might be more to do with the diff and right foot. :lol:
RJT
Re: 17/18th may
Post by RJT »
Shrapa wrote:I had the privilege of having someone modify my truck for me.
I feel your pain! Some asshat boy racer decided he/she didn't like my steering/suspension setup so they very kindly adjusted it for me with the front of their car outside my house at 2am.
Quiet suburban street and a 30m brake lock up. And of course the shits buggered off straight away.
Lucky for me no panel damage but possibly a busted upper A-arm and ball joint plus maybe bent drag link and tie rod.
Lucky for them they missed my front bar or they'd have been toast!
If anybody knows somebody who stacked a red subaru last night please punch them in the nose for me!
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
Filthy4x4
Re: 17/18th may
Post by Filthy4x4 »
Did some work on the truck with Datsunsafari and andy3542 on saturday, then spent today at woodhill 8)
Was good to get out the house, even better to see the amount of trucks supporting Roger lately. Its getting very wet up there again :mrgreen:
027 MUD GEAR - (027 683 4327)
Check our facebook:
catalystracing
Re: 17/18th may
Post by catalystracing »
Did Odlins Rd with the club. The track has more damage than a few months back when last in there 8) . Some folk have a done a great job of working on the slip and made the entry to it much better. Stopped for lunch at hut and chatted with a few like minded guys who were in for a play also. Headed back out in time for a play at a local swamp mmmmmm :oops:
I followed AJ trough a tricky bit, Im mean we have 4 capable trucks and 3 winches, what could possibly go wrong :roll:
Ok so I didnt follow him for long :lol: , thats ok Noel can snatch me out backwards mmm bugger, well never mind Jason can winch Noel while attached to me. ( strop to tight to remove now )....his truck dies, not all is lost AJ can come back across and winch noel and then me out...plan sorted.
So we now have daylight diminishing and oh yeah AJ got stuck on the way back...this is not funny anymore, well hell we still laughing but talk was more serious about recovery now, a friend with twin lockers and a winch was called up, what do ya mean his winch isn't working... :roll: .
Now my motor has been in the river for over an hour and the all the dash warning lights are on, the alternator was wet and not charging, the viscous fan is locked on full time water blasting the engine bay, it just gets better and better :oops:
Even with AJs winch hooked up with a pulley block, it wouldn't budge. After a few more failed snatch attempts where digging etc didnt help,( even sheared two new grade 8.8 bolts off the rear tow hook ) we hi-lifted the back end up and quickly shoved it side ways out of the ruts with diff now clear we snatched again, once I got drive when the clutch dried out it came out and I drove back between two others down the river at night with no lights :shock:
It just goes to show how quickly Image but with good team work, plenty ready to help get wet and cold and stay till we were all going again, you can get a good result. Thanks for help guys.
Still this will cost me Image, now to dry every thing out... and fall asleep having had a great day.
datsunsafari
Re: 17/18th may
Post by datsunsafari »
Image[/quote]
:shock: :shock: :shock: bugger :(
Lchundy
Re: 17/18th may
Post by Lchundy »
Hey thats my cruiser at woodhill
Reminds me to tape that tail light back in
Green Machine
Re: 17/18th may
Post by Green Machine »
Went to Woodhill for the first time. Awesome trails.
[imghttps://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-frc3/t1.0-9/10257987_10152406336442013_8632090703374796178_n.jpg[/img]
Smurf
Re: 17/18th may
Post by Smurf »
Made a small mod to my dash. 8) 8)
Pico42
Re: 17/18th may
Post by Pico42 »
Smurf wrote:Made a small mod to my dash. 8) 8)
Is that where you hid your security light so no one steals any more winches? :lol:
Smurf
Re: 17/18th may
Post by Smurf »
I shouldn't need a winch now anyway, should I?
Smart **s... :lol:
Weemsy
Re: 17/18th may
Post by Weemsy »
No 4wding for a wee while for me.
Had a disceptomy on t4/t5. Had a 12 mm ball of what looks like mince meat taken out of my spine!
Slowly walking today but still got pins and needles in my feet.....
Had mightyhilux4x4 (grant) and de-ranged (reece) in for a visit though, so still got to talk of v8's, lockers etc so all is not lost :D
slidenyo
Re: 17/18th may
Post by slidenyo »
get well soon chap
Weemsy
Re: 17/18th may
Post by Weemsy »
Cheers dude :D
