Toyota 80 Series and LJ, KZJ Suspension Bushes F/S
Vendors selling all suspension components from shackles to Shocks.
Moderator: Vendors
4wdstuff
Post by 4wdstuff »
Hi,
Have got some genuine Toyota rubber suspension bushes.
80 Series
Axle end of the front leading arm
Part no. 48702-60050
4 are required for a complete set.
Dimensions are ID 16mm, Length 50mm, OD 60mm, Length 40mm
$55 each incl post
Chassis end of the front leading arms
Part no is; Bush, Lower Arm 48061-60010
Dimensions are ID 18mm, Length 60mm, OD 54mm, Length 40.5mm
$65 each including post.
rear upper control arm bushes
Bush Sub Assy, Upper Control Arm 48702-60031
Dimensions are ID 18mm, Length 60mm, OD 50mm, Length 45mm
$55 each including post.
lower control arm bushes.
Bush Sub Assy, Lower Control Arm 48702-60040
Dimensions are ID 18mm, Length 60mm, OD 55mm, Length 45mm
KZJ and LJ Leading and Trailing Arms
Axle end of the leading and trailing arms
Part no. 48702-60050 these are 80 series ones
$55 each incl post
Chassis End of Leading and Trailing arms.
Part no is; Bush Sub Assy, Leading Arm No2 48061-60020
These are $65 each including post.
PM me if interested.
Tim
4wdstuff
Re: Toyota 80 Series and LJ, KZJ Suspension Bushes F/S
Post by 4wdstuff »
Bump
PM me if interested
Tim
http://www.4wdstuff.co.nz
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
Return to “Suspension”
