WTD, BJ70 rear axle/diff.
D1 86
Post by D1 86 »
Require complete bj70 landcruiser axle, drum to drum.
Don't really need arms or handbrake cables.
Open head ok.
mudlva
Re: WTD, BJ70 rear axle/diff.
Post by mudlva »
is that the 8"or 9.5"diff head
and leaf or coil springs
Post by 109 »
BJ70 will be 9.5 diff head
Are you after a semi floater or full?
D1 86
Post by D1 86 »
It's leaf sprung. Pretty sure it's semi floater... Hub doesn't stick much past the drum (10-15mm).
Thanks
Big
Post by Big »
you can use either ff or sf in your truck.. FF ftw as easy to fix if it indeed does break..
D1 86
Post by D1 86 »
Yes, just need one that isn't completely full of woodhill mudpit and has good workable brakes.
Auckland area would be a bonus.
derk
Post by derk »
waste of time trying to keep drum brakes with woodhill grinding paste, go find some callipers and brackets and swap it over to disc brake and you'll never look back :D
mudlva
Post by mudlva »
Got a complete unit here. Pm me an offer
