Nissan Wanted to Buy Used Equipment
Posted: Sun May 25, 2014 7:38 am
by slidenyo
so rather than me just make an individual thread for bits I'd like to acquire,
why not pin this to the top and it can run itself for anyone after stuff and things Nissan related.
firstly I'm after a td42 inlet manifold and long wheel base 2 or 3 inch lift springs for a patrol
Re: Nissan Wanted to Buy Used Equipment
Posted: Sun May 25, 2014 9:44 am
by Trundle
I have new 2 and 3" springs in stock 500 for 2" 560 for 3"
Posted: Sun May 25, 2014 8:26 pm
by coxsy
you in a hurry for the inlet, soon as my modded one is built,
the one on the truck will be available.
wow ,you understood that first bit I wrote ,you doing well.
Posted: Mon May 26, 2014 5:12 am
by slidenyo
not too much coxsy,
was just after one to drop into steel surgeon (carlos) so that I can have it modded as well.
thinking of welding a heavy wall box section to the top with a 10-15mm slot along the length of the mating surface and through the original manifold so that the end cyclinders don't starve if I up the fuel/boost
