What radiator is it
Mt Blewit
Stropper
What radiator is it
Post by Mt Blewit »
Hi on my 2.4 Surf Auto is a radiator below the sump in a horozonial postion that is pretty stuffed , person drove it without a sump gaurd. :?:
how may bolts hold it on and is there a set procedure to remove it to install a new one
Thanks in advance
Ross
tweake
Re: What radiator is it
Post by tweake »
thats the aircon radiator.
if the aircon doesn't work get rid of it. otherwise its a shop job to replace and regass.
for any decent 4wding get rid of the radiator and make a decent bash plate.
made mine a little different to give more clearance around the bottom of the radiator.
Mt Blewit
Stropper
Post by Mt Blewit »
Hi again hard yaka
Ok on the radiator
,How may bolts hold it on
Have got another Add actuator to test on the vaccum line
Ross
tweake
Post by tweake »
Mt Blewit wrote:Hi again hard yaka
Ok on the radiator
no frigen idea (mine was front mount). put your head under there and have a look.
