shove a litre of diesel in the oil and let it idle for 10 minutes then dump it(repeat as nessassary) Don't rev it.
I take it that it isn't turbo charged? use the search function here to see pics of how to increase fuel may help.
1991 nissan navara TD27 engine issues
Re: 1991 nissan navara TD27 engine issues
ChurchurDan
Get a compression test done, with sludgy oil and no air filter it is probably poked.
It should do a 100ks no problem they just take a bit of time getting there.
Check the fuel filter, when I got my terrano it was gutless as, took out duel filter and found heaps of sludge etc. new one installed and goes like a bat out of hell..sort of
Also check the valve clearances, the valves have a habit of wearing holes in the rockers
