What is this?
What is this?
I was in the process of removing the head on my 2l-t and found this floating around under the engine, I am not sure what it is and I don't think that I disconnected it when removing the radiator or starting to take the turbo off.. It appears to be a position sensor of some sort..
Re: What is this?
its the motor which sits on top of the shock to change it from normal to hard settings. i guess you don't have standard shocks anymore. it can be unplugged and removed.
Re: What is this?
Awesome thanks for that it is good to know that it isn't a big deal
