80 series rims/tyres
hamishh
Post by hamishh »
Hi I got a 95 80 currently running 33's on 16's also truck got a 2 inch suspension lift. Am looking at going down to 15x10 and maybe looking at getting 35's any suggestion on brand or where to get also will my truck complain if I put bigger tyres without lifting higher??
Thanks
Suza
Re: 80 series rims/tyres
Post by Suza »
If you haven't already check that you can put a 15"rim on some have slightly bigger brake rotors/disks which means 15" rims don't fit.
A mate found this out the hard way with a brand new set of rims and new simex's
Big
Post by Big »
Suza wrote:If you haven't already check that you can put a 15"rim on some have slightly bigger brake rotors/disks which means 15" rims don't fit.
what he said.. 94-95 I think was close to the bigger brakes and 16" so check first
a80crewza
Post by a80crewza »
You should be sweet with a 2 inch and 35s, as I am:
http://www.offroadexpress.co.nz/Forums/ ... =5&t=36821
