Hello
Hopefully someone out there has a pile of broken hilux diff heads . I am after a couple of drive flanges and the nut if they are to hand . I'm in akl but can't be too pricey to post .
Thanks
Chris
Wanted - Hilux diff drive flange
Re: Wanted - Hilux diff drive flange
Rotazuk wrote:Hello
Thanks
Chris
What size heads are they going on.... not all pinion flanges are equal lol
your 4.8 has a smaller spline size, there is also a diff in bolt pattern on some of the early hilux stuff.... I just can't remember the details for it, but I can remember swopping flanges from one diff to another
If you get stuck PM me details on bolt pattern and major spline dia and I'll have a dig through my parts tubs lol
Hey reece, have a look in that bread basket of bits of mine, there was a couple of hilux flanges in that (if that stuff is still there now)
Weemsy wrote:Hey reece, have a look in that bread basket of bits of mine, there was a couple of hilux flanges in that (if that stuff is still there now)
lol thats in clive's area..... somewhere
It could never be found then lol
- Rotazuk
De-Ranged wrote:Rotazuk wrote:Hello
Thanks
Chris
Its not going on a diff so can be made to fit . I was unable to easily pull the one off I have already to check but expect (hope) its a typical hilux one of late 80's etc . Could be interested in a smaller spline size so maybe I need to hunt down one of those 4.8's to compare .
Chris
I'm guessing this is for a mid mounted trans maybe...
you planing on using double carden joints they have a different bolt pattern and a larger Dia flange
Dimensions lol I need dimensions, no point in me sending ya stuff that don't fit
Major shaft dia (dia of peak of the splines) spline count (should be 27) and what bolt pattern or worst case dia of the flange so you can bolt what you want
- Rotazuk
There was no way a double carden joint was going to fit on the suzuki gearbox but this is around the other way so may be more room on the front side . Will see . I want to use a Hilux rear shaft for the rear as it has a hanger bearing from memory (not really familiar with them ) .
Since there are too many options I will come back with details of the flange I have and see what would be best . That will be a week or so .
Chris
Chris
- Rotazuk
Ok , pulled the bits apart today and have measurements .
Flange O/A dia 103mm
Bolt Dia 85 ( first read as 86 ) , seem to be a sqaure pattern 60mm apart .
Best guess on the spline O/D would be 27.5 or 28mm . The seal run area is 38mm but maybe they all are .
Since a suzuki spline is the same size I am scared this is the small spline H/P flange you talk about .
However on the new project I can go up to a 40mm O/D spline .
So what is it and anyone got any they want to part with ?
Thanks
Chris
Thanks
Chris
Just spotted this, if I go in tomorrow I'll have a measure up.... don't think there is anything remotely close to 40mm
- Rotazuk
Bump
No one out there with a couple of hilux pinion flanges and nuts ? ~ 28mm spline .
Better start saving up for some new ones then I guess .
Chris
Chris
- Rotazuk
Did you get my latest PM De-Ranged ?
Just thought you are a busy man but every time I look at this site I am reading other peoples messages incl ones to site admin
Chris
Chris
I'm back home, sorry mate just been down welly's working
text me your address and I'll send you the flanges
o27 541 8794
we can worry about payment someother time lol
o27 541 8794
