Snapped front body bolts
For all Suzuki related topics
Green Machine
Post by Green Machine »
Hey all. So was doing a body lift and both bolts that hold the body to the chassis at the front have snapped off with no studs sticking out.
I need some options on how I can fix this. Its a bitch to get at.
I thought about drilling a 1inch bottem then drilling out the bolt completely and putting a nut on through the hole.
Has anyone else dealt with this situation? Whats my best option?
nztimr33
Re: Snapped front body bolts
Post by nztimr33 »
drill them out would be the only option really unless you can soak them in wd-40 , crc penetrate or something like that and try to use a easy out on them but if they snapped chances are their bloody tight , other option is if you get a oxy torch in there and try heat up the bolt it might loosen it enough to get it out , Good luck :)
COILY
Post by COILY »
Grind them off flush then drill a new hole right through and put a longer bolt with nut underneath.
Smurf
Post by Smurf »
Can you weld to them?
Weld another bolt or a nut to them and while hot gently wind them in and out a bit to loosen, soak in WD40 or similar and gently wind tem out.
redzuki
Post by redzuki »
From memory those captive nuts on the front body mounts are just spot welded on .Id try to break the spot welds with a sharp cold chisel from the side and a long punch from the top . Them just replace the captive nut with a nylock nut and flat washer.
Green Machine
Cheers for the replies guys, I just drilled the bolt out then cut a small hole in the chassis so I can get a nut up and on end of the bolt.
Return to “Suzuki”
