unusual wobble at 100km
J_Dub
Post by J_Dub »
So just purchased an r50 terrano for a steal. Gona fix it up to sell just needs some minor or things fixed.
At 100km/h if I hit an undulation in the road the truck wobbles in a way as if the body is moving about the suspension. So the wheels remain straight and true and driving in a straight line, steering wheel fine, but the body feels as if it's wobbling and shaking. Hard to explain. Its not aggresive, just a smooth wobble. Then stops. Quite a freaky sensation though.
Any ideas to check first up. Bushes? Shocks? Rear shocks look new, fronts look old.
Jared
zukmeista
Re: unusual wobble at 100km
Post by zukmeista »
Panhard rod bushes maybe?
ChurchurDan
Post by ChurchurDan »
Check all the rear suspension bushes they are very common to fail and cause a nasty wobble.
lax2wlg
Post by lax2wlg »
1. Wheel balance
2. Alignment
3. Inspect/Adjust/repack wheel bearings
Crash bandicoot
Post by Crash bandicoot »
yeah these things flog bushes faster then they use a tank of gas.
DEATH_INC
Post by DEATH_INC »
Yup, if it feels like it's wagging it's tail it'll be rear arm bushes...common as.
J_Dub
Post by J_Dub »
OK cheers.
Actually wagging its tail is exactly how u would describe it.. :D
Also just checked tyre pressures, suppose to be at 51psi they were all 25-29 psi. Can't help
zukmeista
Post by zukmeista »
J_Dub wrote:Also just checked tyre pressures, suppose to be at 51psi
:shock: Doubt it that is probably max inflation pressure, should be running around 30-35psi unloaded.
Yup. What he said......
open drivers door and look for a sticker that has the recommended tyre pressures on it
J_Dub
Post by J_Dub »
Checked tyres and all I could see was a max pressure. No recommended pressure. They stated 51psi max cold. Thought that seemed high but as there was no other reading and they did seem a bit under inflated I thought maybe correct
3VILC
Post by 3VILC »
Pretty sure the sticker on my r50 says something stupid like 28psi I always run them around the 32-34 mark feels way too soft on anything less
tweake
Post by tweake »
J_Dub wrote:Checked tyres and all I could see was a max pressure. No recommended pressure. They stated 51psi max cold. Thought that seemed high but as there was no other reading and they did seem a bit under inflated I thought maybe correct
thats max pressure at maximum weight. theres no way your going to be that heavy. try a couple of different pressures up and down, some tires will run better at lower pressures others at higher pressures. the 30-35 would be a good start point.
timmay556
Post by timmay556 »
I had simlar in my GQ, I fitted a better wheel bearing system (from the GU's) and gave my steering box grubscrew an 1/8th of a turn and BAM drives like an arrow.
Return to “Tool Shed”
