td42 larger plunger
Posted: Mon Jun 16, 2014 6:03 pm
by y60 safari driver
hi quick question, is the larger plunger they fit to the injector pumps when fitting a turbo from the td27t pump or is it only the compensator you can use from them?
Re: td42 larger plunger
Posted: Mon Jun 16, 2014 6:07 pm
by Trundle
The plungers are the same size non turbo to turbo only the AFC is on the turbo pump (active fuel control or boost compinsator , ) the gu pumps had an 11mm plunger on the ve pump though ,
