After a number of years of design and testing, we are very pleased to introduce the new range of Terrain Tamer Adjustable Shock Absorbers.
These Shock Absorbers are a mono tube design with an 8-stage valving system so the user is able to adjust the compression/rebound setting to suit their requirements on different road conditions.
These units also contain a remote nitrogen canister that prevents oil foaming, allowing extremely efficient cooling and dramatically reducing the possibility of shock absorber fade.
The adjuster is positioned on the remote canister to ensure protection from breakage and ease of adjustment.
*46mm Piston with Teflon
*20mm super polished shaft
*53mm outer body
*floating piston inside reservoir
Fitment:
MTGSHZJ75F (FRONT)
TOYOTA LANDCRUISER HZJ75 1/90-
MTGSHZJ75R (REAR)
NISSAN PATROL
GU 12/97-
GU-RD28T 12/97-
GU-RD28TI 12/97-
GU-TB45E 12/97-
GU-TB48E 12/97-
GU-TD42 12/97-
GU-TD42T 12/97-
GU-TD42TI 12/97-
MTGSVDJ79F (FRONT)
TOYOTA LANDCRUISER VDJ79 1/07-
MTGSVDJ79R (REAR)
MTGSNGUF (FRONT)
NISSAN PATROL
GU 12/97-
GU-RD28T 12/97-
GU-RD28TI 12/97-
GU-TB45E 12/97-
GU-TB48E 12/97-
GU-TD42 12/97-
GU-TD42T 12/97-
GU-TD42TI 12/97-
GU-ZD30DTI 12/97-
MTGSKUN26F (FRONT)
MTGSKUN26R (REAR)
TOYOTA HILUX KUN26 3/05-
MTGSND22F (FRONT)
MTGSND22R (REAR)
NISSAN NAVARA D22 2/97-
MTGSP120F (FRONT)
MTGSP120R (REAR)
TOYOTA LANDCRUISER PRADO
GRJ120 9/02-
RZJ120 9/02-
KDJ120 9/02-
KZJ120 9/02-
GRJ150 8/09-
KDJ150 9/02-
