opinions on nissan terrano
Posted: Wed Jun 18, 2014 2:42 pm
by peanut.901
hi everyone im thinking about swaping my pajero for a 1992 nissan terrano 2.7 turbo d manaul 2inch lift 32s. what does everyone think of them ?? cheers
Re: opinions on nissan terrano
Posted: Wed Jun 18, 2014 4:29 pm
by Crash bandicoot
peanut.901 wrote:hi everyone im thinking about swaping my pajero for a 1992 nissan terrano 2.7 turbo d manaul 2inch lift 32s. what does everyone think of them ?? cheers
'what pajero have you got.. for example if your Paj is a gen 3 2.8 TDI I'd stick with that, I only got rid of mine as it was a 3L v6 and the engine was a lemon.
Posted: Wed Jun 18, 2014 5:09 pm
by marmel
Make sure you lift up the rear seats on any Terrano of that Era and look very closely for any rust or previous repairs.
Posted: Wed Jun 18, 2014 5:58 pm
by peanut.901
my pajeros swb 2.5 turbo d
Posted: Thu Jun 19, 2014 10:22 am
by lax2wlg
This you?
If so keep it. Pretty much impossible to beat stock-for-stock
Posted: Thu Jun 19, 2014 12:20 pm
by J_Dub
lax2wlg wrote:This you?
This statement is getting thrown about quite a bit.
Is possibly a true statement when only comparing with other ifs trucks.
But yes if wheeling is its main use, the paj is much tougher
Posted: Thu Jun 19, 2014 1:52 pm
by lax2wlg
Not really. As an overall trail vehicle the Mitsu will piss on a lot of solid axle trucks out the box and has a lot of features that others dont, like an LSD that actually works and low factory gears, and exceptionally durable running gear.
Not really, it just better in stock form (albeit more compicated), they got the steering right from the factory. According to this the OP's diesel Pajero has a 7.25" front end which is actually smaller in diameter than the front diff in the diesel Nissan he is looking at swapping it for. Apples for apples :wink:
Gen 2
3.0V6 :-
same as Gen 1 except for NH & NJ auto has 7.25" diameter front diff (high pinion) NH & NJ 5sp man has 8" diameter front diff (high pinion)
2.5TDI :-
same as NH & NJ auto
3.5V6 & 2.8TDI :-
front axle = 28 spline, 29mm diameter, diff = 8" diameter (high pinion)
rear axle = 31 spline, 33.5mm diameter, diff = 9.5" diameter
http://www.offroadexpress.co.nz/Forums/ ... 24&t=27277
Posted: Thu Jun 19, 2014 2:31 pm
by derk
lax2wlg wrote:As an overall trail vehicle the Mitsu will piss on a lot of solid axle trucks out the box
Which ones :D
Posted: Thu Jun 19, 2014 2:59 pm
by KIWI_TERRANO
Mate does comps and coast trips in his paj running 33 and 35 and never seen him break a diff or major issues better than terrano i had
Posted: Thu Jun 19, 2014 4:06 pm
by peanut.901
yeaaah man thats my truck! so you reakon keep it??
Posted: Thu Jun 19, 2014 4:32 pm
by Crash bandicoot
peanut.901 wrote:yeaaah man thats my truck! so you reakon keep it??
yeah keep it, As i said I only sold mine as the engine was a lemon but the truck was very capable.
Posted: Thu Jun 19, 2014 6:27 pm
by ChurchurDan
The only thing about the terrano that is better is the engine.
Posted: Thu Jun 19, 2014 8:34 pm
by peanut.901
ive never been stuck
Posted: Thu Jun 19, 2014 9:03 pm
by J_Dub
peanut.901 wrote:ive never been stuck
Only cause your not trying hard enough
Posted: Thu Jun 19, 2014 9:20 pm
by peanut.901
mate i try lol my foot just gets glued to the floor lol
Posted: Fri Jun 20, 2014 11:28 am
by lax2wlg
ChurchurDan wrote:The only thing about the terrano that is better is the engine.
I'm not going to say better because I don't to start any sh*t...and I genuinely don't think one is an overall better vehicle than the other... but I am going to point out some factual differences. :P
-Wheelbase - Nissan is 104" vs 95"
-Physical dimensions - the Nissan is a slightly undersquare design giving it lower COG. (66" wide x 65" tall) versus (66" wide x 73" tall).
-Deeper transfer reduction of 2.02:1 compared to 1.925:1 for 2.5 TD Mitsu
-Much simpler (less clever, basic) transmission, no center differential, 100% mechanical, fewer moving parts, no computers.
-No clever but complicated multimode ABS in the Nissan
-4-link rear suspension as opposed to trailing arms (or in this case lief springs)
-Being base model this one probly has a drum braked rear end, Nissan all discs except the very early non turbo TD27s.
-31 spline 9.25" rear end compared to this ones 28 spline 9" rear end.
I think old Mitsus (and Isuzus for that matter) are highly underrated and I always like to support the underdog.
Posted: Fri Jun 20, 2014 11:38 am
by Mr Revhead
lax2wlg wrote:-Physical dimensions - the Nissan is a slightly undersquare design giving it lower COG. (66" wide x 65" tall) versus (66" wide x 73" tall).
Wouldn't the height of the engine and running gear dictate that more rather than the overall height?
And go the MU's! :twisted: At least I can afford those!
Posted: Fri Jun 20, 2014 11:50 am
by lax2wlg
Mr Revhead wrote:Wouldn't the height of the engine and running gear dictate that more rather than the overall height?
In terms of true COG, probably, yes.
But IMO height is height and still affects vehicle dynamics :D
Posted: Fri Jun 20, 2014 4:44 pm
by Mr Revhead
Ah I see you are from Welly... Yes with your cross winds I understand! :lol:
Posted: Sat Jul 12, 2014 8:32 am
by darinz
peanut.901 wrote:mate i try lol my foot just gets glued to the floor lol
My truck has about 4x the hp of yours and it gets stuck! You need to try some harder tracks before you consider upgrading.
