4 Terrain Clutch kits now at Trundles LTD
Trundle
Post by Trundle »
We now stock a range of 4 terrain clutch kits !
Td42 upgrade for $680 inc gst (rrp 1250 inc ).
4Terrain Clutch Kits are a strong, durable and tough clutch while still retaining the fine modulation and accurate pedal feel required for navigating difficult terrain. Features engineered specifically for 4x4 applications include:
•High Capacity Cover Assembly – Higher Torque capacity is achieved by the use of components designed to provide the strength, thermal properties and durability required to increase torque capacity and reduce slipping over a wider temperature range.
•Spheroidal Graphite Pressure Plate Casting - Sometimes referred to as Anti Burst, Spheroidal Graphite or nodular iron, this material provides approximately three times the burst strength of a standard cover assembly pressure plate. This increased strength not only extends the life of the casting but combined with its improved heat dissipation, allows the clutch to run cooler in extreme situations.
•Off Road Clutch Plate – Engineered specifically for the unique environment this design includes features unavailable elsewhere.
•Two stage friction material
•Optimised mean effective radius characteristics
•Premium Grade Friction Material
The combined effect of the High Capacity Cover Assembly with Spheroidal Graphite Casting and the Off Road Clutch Plate provides a rugged, strong clutch system that retains the characteristics required for driver control and comfort.
We use this exact clutch in our high power td42 running a big holset and big plunger pump is the best bang for your $$$$ on the market !
Trundle
Re: 4 Terrain Clutch kits now at Trundles LTD
Post by Trundle »
If you are after an upgrade for a specific model let me know and I shall give you a price !
andrew007
Post by andrew007 »
1kd Toyota?
Trundle
Post by Trundle »
upto 2008 or after 2008 mate ?
early model is 260mm and late 275
$780inc gst for the kit they usually rrp at 1350 plus gst ,
These are a far better clutch than the safari tuff ones we use to run
