80 series fuel pick up
Posted: Fri Jun 20, 2014 5:12 pm
by a80crewza
Has anybody had any experience with checking/cleaning out their fuel pick up in the fuel tank? I am thinking mine may need a clean? I have a funny idle, barely noticeable, but told it could be my injectors... I also notice (maybe its just me) a loss of power sometimes, unsure if the fuel pick up could contribute to these problems?
Thanks.
Re: 80 series fuel pick up
Posted: Fri Jun 20, 2014 5:22 pm
by suzolla
Yes,
When I took mine out it was a bit dirty, was a while ago but pretty sure access is under the passenger side rear seat under the carpet.
Tim
Posted: Fri Jun 20, 2014 5:31 pm
by a80crewza
suzolla wrote:Yes,
Tim
Thanks. Did you just take it out and clean it with water? How did you clean out the sump (if it has crap in it)?
Posted: Fri Jun 20, 2014 5:42 pm
by suzolla
Just used an old tooth brush and some petrol and then some compressed air.
Pretty sure there is a bit of access in the top of the tank to do a bit of cleaning.
If really bad may need to drop the tank, hopefully not.
Tim
Posted: Fri Jun 20, 2014 7:57 pm
by a80crewza
How do I get the air out of the system once I put it all back together?
Posted: Sat Jun 21, 2014 4:32 am
by lexlux
when i pushed my cruiser past the 100 kms / hr mark it had a big flat spot & a blocked pick up was the problem .
theres a tool mechanics have its like a weed sprayer only when you pump the handle it sucks , he used this to clean the tank .
when you take the pick up out theres a baffled of area were it sits & this was full of shit .
as for bleeding pull the hose of at the pump & use the manual primer when fuel appears put the hose back on ,job done .
