FJ40 Needing transfer case and front drive shaft.
Anyone know where these can be found?
redz driver
Re: FJ40 Needing transfer case and front drive shaft.
where abouts are you i have both
Real men drive swb leaf spring trucks
Hi Hard Yaka, I've seen you all over this forum, or youtube or something.
I'm in Hamilton. Where are you?
Managed to find the preferred split case kind (and drive shaft), only to discover that it won't bolt on to where my non split one comes off.
So I guess I need the non split kind or to also replace the gear box?
Please your help would be appreciated.
redz driver
im in feilding and have a one piece transfer case but needs a bearing on the output shaft
Hi, I have a 4 speed gearbox with transfer which is surplus to requirements.
The gearbox has a dodgy 1st to 2nd syncro but the transfer is good. No parking brake drum.
I'm in Auckland.
I'm in Auckland.
'78 FJ40
