Hey Guys
Trying to track down the cable on the passenger side seat that has a eye either end that pulls the arm which allows the seat to fully slide forward it also has two flats either end that fix it to the seat tilt mech it is on the side on the seat under the plastic cover that has the tilt lever on it ...have tried making one which worked for a bit but not really the one ,,,,anyone have one they would sell or know where to get one??not sure if nissan do them without having to mortgage the house!! any help appreciated.
Safari swb passenger side seat tilt Cable
Re: Safari swb passenger side seat tilt Cable
Not sure if it will suit the patrol but I've done similar using steel fishing trace and crimps for seat cables. worked as well as the original.
yeah i reckon it would ,,,,just need some steel 6mm eyelets ,,the electrical ones last two seconds haha
I used a light chain.
Mine had a bit of solid wire like a bit lighter gauge than a coat hanger with a couple of cable ties to stop the loops at the end bending undone
Still struggling to get one ,,,,this is the cable on the side of the seat not the ones underneath it activates the slide forward when the seat is tilted, eye each end with circlips ,,,anyone got one lying round they would sell?,,,,have tried making one but unsure of eye to eye length as old ones history
