rn110 1kz conversion
j_tomo
Post by j_tomo »
Hi Guys
Im about to tackle a conversion on a ifs exta cab 4x4
currently running a 22r :oops:
donor truck is my old kzn165
theres heaps of info around for the ln### conversion but not the rn### from memory the engine mounts are in a different position
at this stage im unsure if ill go to a manual fuel pump seeing as the whole donor truck is available
what other dramas go on? sump clearances ect?
the old girl also runs a push button type 4wd g52, may be less dramas sorting out the r151 maybe
any advice or likely dramas ill be running into?
thanks
Jeremy
bigstu
Re: rn110 1kz conversion
Post by bigstu »
Should be cool what happened to the 1uz surf?
j_tomo
Post by j_tomo »
sold it to buy a house.......
cool truck it was fwd till I had a rear shaft made up, sob used to tourque steer off the road
with the latest truck im working through the manual fuel pump dramas
