Lada not running right but might be a cheap fix- cheap truck...
http://www.trademe.co.nz/motors/used-cars/other/auction-750921381.htm
Lada going cheap
Lada going cheap
It's just more fun in a lada !!
- KIWI_TERRANO
Re: Lada going cheap
rotordogg wrote:Lada not running right but might be a cheap fix- cheap truck...
For starters its not fuel injected and nor 1700cc as its the carby model
Probably just a bung spark plug
Its got a heated rear window which will keep your hands warm when you push it
KIWI_TERRANO wrote:rotordogg wrote:Lada not running right but might be a cheap fix- cheap truck...
I disagree, this one is more than likely the single point injection model 1700, they had an air cleaner that was similar to the 1600 carby model and as well as that there is no distributor as these were distributor less.
