FS AKL. 2-4inch panhard drop bracket Suit KZN/VZN130
Sheepy
Post by Sheepy »
Purchased from Toms OFFroad about 2 months ago. Suit KZN130 VZN130.
Has been fitted, but comes with nylock nuts and bolts.
I had it in my truck, but i think my panhard road isn't factory so It's surplus. Cost me $220 how does $150 Shipped sound? If not to your liking, make me an offer, better sold than sitting here doing bugger all.
zukmeista
Re: FS AUCKLAND. Toms Offroad 2-4inch panhard drop bracket.
Post by zukmeista »
I would have thought the price would be higher for a universal bracket that will fit anything that has a panhard rod... :roll: :lol:
tomsoffroad
Flopsie
Post by tomsoffroad »
zukmeista wrote:I would have thought the price would be higher for a universal bracket that will fit anything that has a panhard rod... :roll: :lol:
Kzn/ln130
Sheepy
Post by Sheepy »
Wow. I am miles away. Ill update the thread.
tweake
Re: FS AKL. 2-4inch panhard drop bracket Suit KZN/VZN130
Post by tweake »
what lift is it made for?
never seen one suitable for different sized lifts unless toms somehow made it adjustable.
Sheepy
Post by Sheepy »
Im just going off the info Toms posted me.
tweake
Post by tweake »
can you measure it?
distance between the two main bolt locations.
tomsoffroad
Flopsie
tweake wrote:what lift is it made for?
Nah not adjustable. The difference between 2-4" is about 5mm of lateral positioning. Not really enough to worry about. It does make them drive a lot better with the panhard closer to horizontal, gets rid of that twitchiness the rear gets once ypu lift them
tweake
Post by tweake »
tomsoffroad wrote:Nah not adjustable. The difference between 2-4" is about 5mm of lateral positioning. Not really enough to worry about. It does make them drive a lot better with the panhard closer to horizontal, gets rid of that twitchiness the rear gets once ypu lift them
if you fit a big bracket on small lift you end up being out the other way. ie 4' bracket on a 2" lift you end up still out by the same amount.
tho its more about panhard angle than just lateral position. better to be out and have flatter panhard than to be out the other way.
