underside pics of vitra
Posted: Fri Jul 11, 2014 11:39 am
by skidtoy
anyone able to post up some pics of the underside of a 4dr early 90's vitra?
wanting to have a look at acouple of things as trying to decide if I should go this truck route with a sas build. thanks
Re: underside pics of vitra
Posted: Fri Jul 11, 2014 1:37 pm
by churchill
Where do you live? I'm doing a SAS on mine, if your nearby I would like to show you some of the issues I've had and pass on some tips in terms of axle selection etc.
Posted: Sat Jul 12, 2014 7:19 pm
by skidtoy
im in New Plymouth but am up in Auckland quite abit so might have to come have a look at some point when work allows.
are you doing a road legal truck? im not it will only be a trailer truck so im not worried about cutting out whatever I have to to make things fit. I have patrol axles that I will be using and a number of other patrol, hilux parts laying around.
Posted: Sun Jul 13, 2014 7:02 pm
by churchill
Yeah it's road legal, you've got good axles by the sound of it. Just be careful of the gearing as the std diffs are quite low ratio. Pm me when you want to come and see it.
Posted: Sun Jul 13, 2014 9:14 pm
by skidtoy
yea I will either re-gear the diffs but will most likely do a gear set in transfer as will either run 35 or 37's again.
what diff have you used? have you stuck with Suzuki to keep the track width for cert etc
