stupid sj413 stater
Posted: Sat Jul 19, 2014 9:53 am
by Rocko
having heaps of trouble with my starter clicking like its solenoid? have tested on bench and runs fine, does what it should, brushes are fine . . .
will start fine if you bridge starter with screwdriver. HELP what next???
Re: stupid sj413 stater
Posted: Sat Jul 19, 2014 10:12 am
by Campbell.s
Check the voltage drop across your pos and neg leads and across engine earth, should be no higher than 0.5 volts, if it is you've got a high resistance in a connection or lead itself
Posted: Sat Jul 19, 2014 11:49 am
by zukmeista
You may need to run a relay for the trigger circuit using the standard trigger wire as the activation for the relay. The standard wiring is only just adequate from factory and over the years some of them lose a bit of current carrying capacity which is enough to stop it working. The fact that you can bridge it and it works fine points to this being the case IMO.
Posted: Sat Jul 19, 2014 12:31 pm
by Rocko
got any more info on how to wire relay?
Posted: Sat Jul 19, 2014 2:43 pm
by zukmeista
Posted: Sat Jul 19, 2014 3:57 pm
by Rocko
just what I'm after, is the relay like the spotlight relays you can you get??
Posted: Sun Jul 20, 2014 12:39 pm
by diogenese
yes
You can use a 4 or 5 pin relay, just ignore the middle pin if you get a 5 pin one.
