Terrano Ball Joint Spacers
Posted: Mon Jul 21, 2014 10:10 pm
by johnny262
Anyone with any first hand experience on this subject?
In need of a teeny tiny bit more downtravel on my wd21, so would only go 1/2" spacer max, will eventually be running 32" Buckshots or Bighorns
Open r180a, 3x2 CV's, 27 spline hubs atm, yea yea weak as piss blah blah :lol: , will upgrade if need be
Im well aware of the possible implications, might have to just give it a nudge and find out eh?
Re: Terrano Ball Joint Spacers
Posted: Mon Jul 21, 2014 11:05 pm
by lax2wlg
johnny262 wrote:Anyone with any first hand experience on this subject?
Yes, cracked factory upper control arms around the balljoint mounting bolts. IMO dont do it.
You'd be surprised, if its set up correctly (keep the droop controlled) and you're half concious when operating it.
But yeah, junk.
Posted: Tue Jul 22, 2014 8:46 am
by ChurchurDan
After market upper arms would be better and you would also want to get some diff drop bushes to help with cv angles at full droop.
Posted: Tue Jul 22, 2014 1:44 pm
by johnny262
Any idea why they cracked? Extra leverage?
And yeah was thinking along the lines of diff drop to compensate for the added droop
Heard about (probably read on here) having trouble certing aftermarket arms? Can low profile bumpstops on original arms be certed?
Appreciate your feedback
Posted: Tue Jul 22, 2014 3:47 pm
by lax2wlg
johnny262 wrote:Any idea why they cracked? Extra leverage?
I'm guessing so... theres a tonne of force pushed through those BJs when you bottom out, particularly hard if doing a jump etc...
I used to wheel with a guy who had an old Isuzu Trooper with 5.13s and front/rear Aussie lockers, and 34x9.5 TSLs. Thing's performance would scare the shit out of anyone and was strong as an ox. He had zero problems until he tried BJ spacers and playing with the bumpstops... then he had all sorts of things happen, with bent tie rods and bent idler arms to show for it.
I had no prob certing mine, just showed him the factory stampings on the arms and the install manual from Superlift. The arms I'm using are made of .219" wall thickness DOM tubing and .25" thick steel plate. http://www.superlift.com/pc_product_detail.asp?key=8DB4C9F5F1BE49B28F36AD8C28A60C9C
Here is a pic of the setup, also using diff drop bushings on the two crossmembers that locate the front diff: Image
Aftermarket Arms are awesome IMO but not necessary. As you can see there is room for more droop, but I prefer this setup as it means I trade off a bit of extension travel for strength... generally when trying to get up steep rock ledges, the front will be at full droop (I'm working on a way of controlling this ie manually compress the spring on demand)... anyway with a locked front I would prefer to be able to hammer it if necessary without worries about the excessive CV angles and therefore the risk of breakage.
Personally I'd just make sure the droop/compression bumpstops are firmly im place, soften up the torsions and leave the susp. alone.... at factory settings it works well and with the correct backspacing you can run 33x10.5 or 34x9.5 on these vehices with 0" lift.
I'd focus on the steering upgrades - An IFS steering system has to work extremely hard, particularly if locked or on high speed whoops sections... tierods constantly tugging on the draglink... Personally I'd go steering box idler (or idler brace if you don't want it to bend it but enjoy replacing bushings), and the 2wd draglink mod. This will ensure reliable service.
Steering is vital and often overlooked ...Until we go to an inverted Y style linkage (such as you would find on a Ford TTB setup or a Jeep live axle) which would delete the idler altogether, reduce the number of rod ends (serviceable moving parts) but in doing so also minimize deflection/toe in under high torque locked scenarios... and come up with a custom dropped pitman arm that would allow the two steering links to run on the same plane as the control arms... until then, I say make it as bomb proof as possible.
$0.02c
Posted: Tue Jul 22, 2014 6:28 pm
by johnny262
Cheers mate, I've got a Calmini idler brace, haven't had any issues with standard set up with wound torsions yet, but gathering bits for 2wd mod and steering box mod just incase that prick Murphy comes for me :mrgreen:
Posted: Tue Jul 22, 2014 7:20 pm
by kiwipete
johnny262 wrote:Cheers mate, I've got a Calmini idler brace, haven't had any issues with standard set up with wound torsions yet, but gathering bits for 2wd mod and steering box mod just incase that prick Murphy comes for me :mrgreen:
I have the tie rods (new), adjusters, centre link (new) and a pitman arm all for sale if you are interested.
Posted: Tue Jul 22, 2014 8:10 pm
by johnny262
PM sent, cheers
