Diff ratio for 1kz on r151f gear box
Camfitz30
Post by Camfitz30 »
I have just done a conversion on my ln130, from a 2LTE to a 1kz, Manuel pump etc on a r151f gearbox. I have a set of 4.11 diffs and a set of diffs out of the 2LTE r151f which I don't know what ratio they are...
Which diffs would be better to get the revs down on the open road? With 31, 32 inch tyres...
Crash bandicoot
Re: Diff ratio for 1kz on r151f gear box
Post by Crash bandicoot »
4.1 that youve got.....for low revs. 4.5 Or 4.8 for crrawling
do a search on google for a diff ratio calculator, there are a couple of good ones out there
kbushnz
Post by kbushnz »
The factory diff ratio's for the 1KZTE powered KZJ78 etc etc was 4.3
2LTE had 4.1
tweake
Post by tweake »
one thing to watch with a 4.1 diff is first gear starts might be a little tough at times. i can't remember what the kn130's came out with. you might want to look at 4.3's. it will rev a bit more in highway use but certainly easier going in the slow stuff and hill starts.
i run 4.56 with 31" and r151f, and it rev's its nuts off. but thats typical for an L series engine. 1kz are generally lower rev'ed.
kbushnz wrote:The factory diff ratio's for the 1KZTE powered KZJ78 etc etc was 4.3
2LTE had 4.1
4.8's for 2lte ones?
kbushnz
Post by kbushnz »
2LTE had 4.1
True thats right doh...... 4.1 was for the hilux...
Thanks Jerry....
Smurf
Post by Smurf »
kbushnz wrote:
2LTE had 4.1
Thanks Jerry....
V6 VZN Surf is also 4.88
UBZ
Post by UBZ »
95 KZN-130 Manual Surf 1KZ-TE with R151F Gearbox/Chain transfer had 4.11 Diffs from factory .
Went real good on 33s with 4.3 diffs though .
