Diff ratio for 1kz on r151f gear box
Posted: Tue Jul 22, 2014 8:16 pm
by Camfitz30
I have just done a conversion on my ln130, from a 2LTE to a 1kz, Manuel pump etc on a r151f gearbox. I have a set of 4.11 diffs and a set of diffs out of the 2LTE r151f which I don't know what ratio they are...
Which diffs would be better to get the revs down on the open road? With 31, 32 inch tyres...
Re: Diff ratio for 1kz on r151f gear box
Posted: Tue Jul 22, 2014 8:35 pm
by Crash bandicoot
4.1 that youve got.....for low revs. 4.5 Or 4.8 for crrawling
Posted: Tue Jul 22, 2014 8:39 pm
by Jerry
do a search on google for a diff ratio calculator, there are a couple of good ones out there
by kbushnz
The factory diff ratio's for the 1KZTE powered KZJ78 etc etc was 4.3
2LTE had 4.1
Posted: Tue Jul 22, 2014 9:00 pm
by tweake
one thing to watch with a 4.1 diff is first gear starts might be a little tough at times. i can't remember what the kn130's came out with. you might want to look at 4.3's. it will rev a bit more in highway use but certainly easier going in the slow stuff and hill starts.
i run 4.56 with 31" and r151f, and it rev's its nuts off. but thats typical for an L series engine. 1kz are generally lower rev'ed.
Posted: Tue Jul 22, 2014 9:27 pm
by Jerry
kbushnz wrote:The factory diff ratio's for the 1KZTE powered KZJ78 etc etc was 4.3
2LTE had 4.1
4.8's for 2lte ones?
Posted: Tue Jul 22, 2014 9:33 pm
by kbushnz
2LTE had 4.1
True thats right doh...... 4.1 was for the hilux...
Thanks Jerry....
Posted: Tue Jul 22, 2014 9:34 pm
by Smurf
kbushnz wrote:
2LTE had 4.1
Thanks Jerry....
V6 VZN Surf is also 4.88
Posted: Tue Jul 22, 2014 10:49 pm
by UBZ
95 KZN-130 Manual Surf 1KZ-TE with R151F Gearbox/Chain transfer had 4.11 Diffs from factory .
Went real good on 33s with 4.3 diffs though .
