Auto locker setup/rebuild
brakes-shocks-lockers-etc
Mazuki
Post by Mazuki »
I have a lockrite auto locker in my 1.6 escudo which I instaled myself. Up until today it's been fine but it has suddenly started making some weird noises and clunks. I am still yet to remove and investigate further but if worst comes to worst, who is the best person to get to rebuild in Wellington? I did a search in the google machine and all that came up was Wellington automotive ( ex miles udy) which I have used before for a past gearbox rebuild. Is there any others?
catalystracing
Re: Auto locker setup/rebuild
Post by catalystracing »
Wow Miles Udy, he helped put a 2l cortina motor in my Mk1 escort with an RS2000 g/box, that was mid 80's :shock:
Mattman
Post by Mattman »
If you can install it you can set it up correctly.
If the clearances aren't right you can end up breaking the springs and pins.
Get the install manual and a set of feeler gauges and you should be fine.
I bought mine second hand and it had broken pins which I replaced.
I had to get my thrust washers machined down to get the clearances correct.
Matt.
