I could use one of the existing bolt holes but not the other one if i was to drill a hole through the top rail i will have probs getting to it to do it up ?.
The orignal tow hook is at least 19mm thick cast steel by the look of it would or could i get away with useing that.
As for the rrear hook thats of no prob as the chassis rails are open at the end so you can get to any nuts etc with a little work.
Any ideas would be most welcome tnx in advance
