Best oil filter(s) for a TD42?
Hi, what is the recommended oil filter (x2) for a 1990 GQ Safari TD42?
Re: Best oil filter(s) for a TD42?
Do you have 2 of the same filters? Double check, allot of them use 2 very different types. The bypass filter is quite a bit more expensive. I used ryco filters but might be better ones.
92 LWB Safari TD42
i use wix filters in mine get them from extreme automotive or ryco
Mr Phux It
webfish wrote:Hi, what is the recommended oil filter (x2) for a 1990 GQ Safari TD42?
Genuine Nissan filters.
Well at least that's what Nissan advise ...........
I've been using fleetguard filters. seems to build oil pressure faster with them than the rycos.
I used the brand that the UD trucks service agent uses can't remember what they were called, mainly cos I got them at cost. Also used ryco. Seemed about the same. Used valvolone diesel extra oil, had horrible oil pressure probs with it for some reason. The last one I used was that calibre stuff from super cheap, seemed better.
But as mentioned prepare for a shock if yours has the bypass filter, is about double the price of the standard filter
having recently just done a filter change on my TD42 putting on 2 of the same filters..
Other than if there is 2 different filters already fitted how would one tell if its meant to be running a bypass filter?
Yael
Yael
If you cant beat us Gingers, JOIN US!!
threads are different for each filter I think.
As above, very different threads.
92 LWB Safari TD42
Any one have a Ryco, wix, nissan part number for the filters?
I can cross reference with Donaldson and get them really well priced.
Any diesel filters or oil filters I can get if anyone wants Donaldson ones?
Just give me a number to cross reference.
One of the ryco numbers is Z115 I think.
ryco numbers z115 x 2 or z416 and z115 depending on setup
If both the filters are the same, the Donaldson part number is P557780.
