Best oil filter(s) for a TD42?
Posted: Tue Jul 29, 2014 12:56 pm
by webfish
Hi, what is the recommended oil filter (x2) for a 1990 GQ Safari TD42?
Re: Best oil filter(s) for a TD42?
Posted: Tue Jul 29, 2014 1:36 pm
by Ant
Do you have 2 of the same filters? Double check, allot of them use 2 very different types. The bypass filter is quite a bit more expensive. I used ryco filters but might be better ones.
Posted: Tue Jul 29, 2014 5:09 pm
by Waddles
i use wix filters in mine get them from extreme automotive or ryco
Posted: Tue Jul 29, 2014 5:46 pm
by Ralfie
webfish wrote:Hi, what is the recommended oil filter (x2) for a 1990 GQ Safari TD42?
Genuine Nissan filters.
Well at least that's what Nissan advise ...........
Posted: Wed Jul 30, 2014 10:10 am
by Swamped
I've been using fleetguard filters. seems to build oil pressure faster with them than the rycos.
Posted: Wed Jul 30, 2014 4:20 pm
by 3VILC
I used the brand that the UD trucks service agent uses can't remember what they were called, mainly cos I got them at cost. Also used ryco. Seemed about the same. Used valvolone diesel extra oil, had horrible oil pressure probs with it for some reason. The last one I used was that calibre stuff from super cheap, seemed better.
But as mentioned prepare for a shock if yours has the bypass filter, is about double the price of the standard filter
Posted: Wed Jul 30, 2014 8:21 pm
by yael
having recently just done a filter change on my TD42 putting on 2 of the same filters..
Other than if there is 2 different filters already fitted how would one tell if its meant to be running a bypass filter?
Yael
Posted: Wed Jul 30, 2014 8:32 pm
by Swamped
threads are different for each filter I think.
Posted: Wed Jul 30, 2014 8:44 pm
by Ant
As above, very different threads.
Posted: Wed Jul 30, 2014 9:06 pm
by Weemsy
Any one have a Ryco, wix, nissan part number for the filters?
I can cross reference with Donaldson and get them really well priced.
Any diesel filters or oil filters I can get if anyone wants Donaldson ones?
Just give me a number to cross reference. :D
Posted: Wed Jul 30, 2014 9:13 pm
by Swamped
One of the ryco numbers is Z115 I think.
Posted: Wed Jul 30, 2014 9:31 pm
by slide
ryco numbers z115 x 2 or z416 and z115 depending on setup
Posted: Wed Jul 30, 2014 10:21 pm
by monterey
If both the filters are the same, the Donaldson part number is P557780.
