Hi
As the title says. Am thinking about lifting my 80 series a further 2in to bring it to 4in so I can use 35in tyres. But at what pound does it become bad for drive line and rest of running gear?
Thanks
At what point does lift become hassle
Re: At what point does lift become hassle
If you want 4" you will need /should do extended rear lower arms , gearbox spacers , extended brake hoses , castor correction ,extended swaybar links , extend your diff breathers , Adjustable panhards ,
We stock most of these parts ,
Dobi springs in 4" for $560 , Amada extreme adventure series shocks are $560 , Adjustable panhards $500 a pair , for an indication
We also do tough dog pahards $600 a pair , Tough dog 4" shocks $860 a ful set etc ,
When you need to jack up the shed to fit the truck in.
Trundle wrote:If you want 4" you will need /should do extended rear lower arms , gearbox spacers , extended brake hoses , castor correction ,extended swaybar links , extend your diff breathers , Adjustable panhards ,
and have it certified.
Tony.
Ok I am a tad cabbage and am still not in the know about castor correction and panhard rods. What exactly are tgey
Give us a ring monday at the workshop 06 75 27 952 and i can take you through all the options and why you do them , Cheers
Trundle
Trundle
castor correction - ensuring you kingpins ie front wheels turn around a near vertical axis on the diff relative to the ground, the more you lift the more angle the diff gets tipped on and also the closer the diffs get together (hence longer arms to retain wheelbase/geometry)
panhard rods- ensure your diffs are in the centre of the chassis
We ran 35s (BFG AT then KL71 as pictured) with 2 inch lift. Only needed minor trimming of the mud flaps and small bumpstop extension.
Pritty sure skid also ran 35s with two inch lift, could be wrong though.
Easy it becomes a hassle when you need a cherry picker to get in
Sorry had to say it
Sorry had to say it
If there's no Blood it ain't Hurt
1999 Jeep Wrangler Sport
OIIIIO
OIIIIO
