Muffler options for TD27T 2.5"
- Shuttle Queen
Hi All
I'm in the process of rebuilding my exhaust for the TD27T. Built a custom dump pipe from the turbo into a 2.5" exhaust.
I just want to take the harshness out of the sound and keep the WOF man happy, but also have no flow restrictions.
A few options I've found so far...
http://www.trademe.co.nz/Browse/Listing ... =760654593
http://www.trademe.co.nz/Browse/Listing ... =760084757
http://www.trademe.co.nz/Browse/Listing ... =759721705
Has anyone had any experience with these and/or can recommend a good muffler option?
- stovanovich
Re: Muffler options for TD27T 2.5"
I have one of these personally, smooths out the roughness but still gives you body & flow
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
what about something like this ?
http://www.trademe.co.nz/motors/car-par ... 474517.htm
I put one on my old dodge sounded just like a Coby but cheaper
Just go straight pipe all the way... forget the mufflers
Works fine. Not that much louder.. And if you dont like it sticth in a coby later...
Flowmaster 40
Straight pipe not much louder really. Is on a toyota for some reason but wof guys have no issues with them on turbo diesel nissans
chuck anything thats straight through on it. the turbo takes most of the noise out anyway.
don't bother with a flow master, their design doesn't work with turbo engine (according to flowmaster site, they have straight through mufflers for turbo engines).
X2 for the Coby (or similar) I personally think the Flow master is a lot quieter, probably half as loud as a straight pipe.
Edit:
This is what the $80something Coby sounds like
Edit:
fullthrottle wrote:Hi All
I just had a 3" incl dump put on my surf 1kz-te and used the scavenging type (1st link) resonator. Good sound and excellent flow. No noise issues at wof and good results on dyno too
Yeah I didnt really consider that about the flowmaster, seems to be fine for my 100hp forklift diesel doing 11psi anyway.
Its definately a lot quieter and not obnoxious sounding, but has a good bark when you 'get on' the fuel pedal.
I think the snorkel/intercooler/dump size/length of exhaust system makes a big difference to the overall sound/character of the thing too.
Every diesel likes to take a good dump
- Shuttle Queen
Cheers everyone for the replies. I've got 5.5m of 2.5" pipe to play with, so I'll do a straight pipe first and then bung a muffler in after if the sound is a bit much.
By the way, if you ever need a flange cut for the garrett turbo (kidney shaped) exhaust outlet, then these guys now have the pattern on file and can cut you one in about 5mins.
Orrsum Laser Services
Ph: 04 920 0079
Ph: 04 920 0079
I just run the 457mm one of these http://www.chase.co.nz/category/105/Louvred-Centre-Tube on mine now, tho it is a little tractor sounding at lower rpm.
If ya want something a little quieter, I ran one of these http://www.chase.co.nz/part/582/0/RD41266 for ages, seem to handle the diesel vibrations no worries, and did sound a lot better than the hot dog does.
screw the mufflers, TD27-t's are quite enough(just) for a WOF with striaght pipe.
it's the hilux engines they WOF guys complain about.
- Shuttle Queen
Crash bandicoot wrote:screw the mufflers, TD27-t's are quite enough
Surprisingly true.
I did go with the straight through 2.5inch in the end. Sounds fine to me and Mr WOF.
I also had to rebuild the little 1.4 Astra exhaust and those things are bloody obnoxious in comparison.
