Lockright or Spartan into Vitara Question for Suzuki Experts
For all Suzuki related topics
suzolla
Post by suzolla »
Hi,
Wanting to to know if the Lockright 1510 or Spartan SL SUZSAM will fit into the rear of a Vitara.
And if not then what would.
Thank you
Tim
nstacey
Re: Lockright or Spartan into Vitara Question for Suzuki Exp
Post by nstacey »
I have a lock right 1510 in the back of my 02 Grand Vitara. Can't tell you how similar the Vitara diff is.
85 Hilux single cab
02 Grand Vitara
Rotazuk
Post by Rotazuk »
I have a early vitara rear diff head in the shed at the moment half pulled apart to install a 1510 lockrite , using it as an alignment guide at the moment but once the housing is welded together the locker will go in . Looks like it should go together just fine . The vitara cross pins need to be used as they are roll pinned in place .
Chris
churchill
Post by churchill »
Be careful with the V6 diff, I had to repair one because the side gears were slightly higher and a different design so caused the locker to bind. Check the clearances on the washers. I've fitted one to a GV and a early 10 bolt vitara rear without any issues.
suzolla
Post by suzolla »
Thanks for the feed back.
Tim
stinky
House Hubby
Post by stinky »
Think possum has a Spartan locker for a vitara she wants to sell shes gone to cruiser diffs
____________________________
Martin
http://www.wtbs.co.nz
Chairmen
Post by Chairmen »
Iv'e fitted a Spartan in the rear diff of a 1600 Vitara an know my mate fitted one in his V6 as well but from memory the V6 had a 1600 diff head with the lower gearing.. However Iv'e had a lockrite 1510 in my truck now for around a year an a half an it has not missed a beat, one of the best mods yet !!!
Return to “Suzuki”
