In this situation above, I classed my lights as Scene lamps.
Yes a few times I was challenged on this, but if the issuer of the WOF is to decline a WOF for your lights; they must show you where it is stated they are not legal in the rule book.
If they don't then they cannot refuse you a WOF by law.
There are no "grey" areas here folks, either the WOF person knows the rules or they have to look them up.
I had quite a heated argument with one chap and have filed a complaint with the LTSA which I am still awaiting a reply, but he passed the lights without question when I went back after other failed work had been fixed?
http://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004.html#x3
Part 2 Definitions
Alley lamp
means a work lamp designed primarily to provide a fixed or movable beam of light to the side of a vehicle to which it is fitted.
Scene lamp
means a work lamp designed to provide a fixed or moveable beam of light to illuminate the area around a vehicle, or the vehicle itself.
Work lamp
means a high intensity lamp, which is not necessary for the operation of the vehicle but is designed to illuminate a work area or scene; and includes:
(a) a scene lamp; and
(b) a spot lamp; and
(c) an alley lamp.
http://www.legislation.govt.nz/regulation/public/2004/0427/latest/whole.html#DLM303647
(a) when the vehicle to which it is fitted is stationary or travelling slowly; and
(b) to illuminate a work area or scene.
8.4 Use of optional lights
(2) A person may use a work lamp only—
http://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004.html#21
Section 2 General safety requirements and approved vehicle standards
2.1 General safety requirements
2.1(9) A work lamp fitted to a vehicle does not have to be maintained in sound condition and good working order.
http://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004.html#107
10.7 Fitting and performance requirements for work lamps
10.7(1) A motor vehicle of Class LC, LD or LE, or of Group M, N or T, or an unclassified motor vehicle, may be fitted with one or more work lamps.
10.7(2) The light emitted from a work lamp must be substantially white or amber.
10.7(3) A motor vehicle of Class AB, LA or LB must not be fitted with a work lamp.
http://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/heavy-vehicles/lighting/cosmetic-lamps
And one for reversing lamps.
