how much power can at TD27 Turbo pump support?
Posted: Wed Aug 20, 2014 2:11 pm
Hi all, I'm in the process of modifying a QD32eti, I want as little electrics on this setup as possible. So I want to use a TD27T mechanical injector pump (with boost Compensator). I'm fitting a TD04 19T turbo which will supply enough air to support 230hp on a TD27 with afr of 21:1. It is equipped with a large water to air intercooler setup and a hi flow exhaust system. Now Im not saying I want to make 230Hp, i would just like to know how much hp a td27t pump can support before moding that pump and fitting a 12mm plunger and head from a mechanical qd32 pump onto a td27t.
thanks
thanks
