Hi all,
Just a quick question, whats the difference between the 1990 80 series cruisers springs VS the 1991 onwards model? are they longer or shorter? Different sized perches?
Rob
1990 80 Series springs different to 1991 onwards?
- tomsoffroad
- Flopsie
Re: 1990 80 Series springs different to 1991 onwards?
All the same as far as I know
Pre august 1991 sat 1" higher from fatory so the springs are longer ,
We stock all the springs for the 80 if that is what your after
I pretty sure its the spring mounts that different on the pre 91,did a 5 inch lift on my 1990 80 and it ended up being 7 inch.Not sure if being oz/nz spec base model petrol makes any diferance
If I remember the standard free height for a 1990 spring is around 525mm. Thats what im using in the front of my coiled hilux.
