Off-roading with airbags
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
Gcdogg
Post by Gcdogg »
Was just wandering if it's safe or not to go 4wding around in a truck with airbags ? Is there a fuse I could disconnect without setting them off ? Or am I safe
Ralfie
Re: Off-roading with airbags
Post by Ralfie »
you are safer with them than without.....
There are fine off road unless you impact a tree or rock at a fairly reasonable speed.
its the sudden stop that actives them, not bouncing around off road.
ChurchurDan
Post by ChurchurDan »
Just make sure you have your seat belt on.
KIWI_TERRANO
Post by KIWI_TERRANO »
Dont wear set belt then they dont deploy under 20kmh is what i got told
Had airbags in my last 3 yets amd havent had issues
Suza
Post by Suza »
They don't arm until 20km, and even then if the impact doesn't exceed a certain amount of force(G's) they wont deploy.
TJ
Post by TJ »
KIWI_TERRANO wrote:Dont wear set belt then they dont deploy under 20kmh is what i got told
Not all vehicles have seat belt sensor connected to air bag system.
If the impact was big enough to deploy the air bags, you would be glad that they did. Normal offroad situations don't deploy them.
Crash bandicoot
Post by Crash bandicoot »
most airbag systems are disarmed in low range. nissan for example.
tweake
Post by tweake »
Crash bandicoot wrote:most airbag systems are disarmed in low range. nissan for example.
i know with some of the nissans, they don't disable airbags in low range, they change the sensitivity of the sensor. you have to hit a lot harder than normal to set it off.
if you hit something that hard and at high enough speed to set it off, you will be thankfull for the airbags.
bang-thud-thump
Post by bang-thud-thump »
Just remember what SRS stand for
SUPPLEMENTARY restraint system. ie it supplements the seat belt.
Unless really quick smacks in the kisser appeal..... Im not so keen -waay to pretty :lol:
Good to hear people haven't had issues though as Im after a wagon with ABS and air bags.
timmay556
Post by timmay556 »
They can kill you and save you all at the same time.
slide
Post by slide »
timmay556 wrote:They can kill you and save you all at the same time.
That must be an interesting feeling. Being killed and saved at the same time :?
3VILC
Post by 3VILC »
I suppose its like any other safety device, in general they will save your life but in the very odd instance they can do more damage than good. Seat belt, broken collar bone or flying out the window, I know which I'd choose haha.
As a morbid example, an old neighbour of my mums rolled his truck going too fast around a sharp bend, barely a scratch on him but the safety barrier twisted thru the cab and broke his neck, thus he is longer with us. Irony at its best. And no its not just Chinese whispers gossip, my dad was a fireman and both my parents were ambulance officers at the time.
Annnnyway, sad but true, any other 360 days of the year he would've walked away
bang-thud-thump
yeah seatbelts can break collar bones but I figure the impact that breaks a single bone with a belt will more than break a whole person without one.
I cant find anything in my car I want to smash my face into so I wear my belt.
Return to “4wd Safety”
