Wanting to fit a Surf trans (G52??) to a 22R engine?? Help p
kaupoi
Post by kaupoi »
Hi guys,
Not mechanic of the year but get by.
Bought a rolled 82 single cab hilux minus its gearbox, it has a 4 cylinder petrol in it, (22R i think??).
Wanting to fix her up so I can use it to launch our boat off the beach.
I was hoping my G series box would fit it but doesnt appear so, starter motors on the wrong side and so is the clutch ativator lever??
Can I just remove the bellhousing from the G series box and fit a bellhousing that will suite the petrol engine??
Your help is much appreciated.
Cheers.
Smurf
Re: Wanting to fit a Surf trans (G52??) to a 22R engine?? He
Post by Smurf »
Yes you will need the right bellhousing then you can swap it onto your gearbox and fit it.
Sounds like you need to determine if it is a 22R or a 3Y engine first though. Info should be on the plate on the fire wall.
Crash bandicoot
Post by Crash bandicoot »
Don't see why not.... the early 2 door surf/4runner came with a 22r/auto combination...the question is which auto thou? May need a toyota parts guru to confirm this for you.
keithal
Post by keithal »
Crash bandicoot wrote:Don't see why not.... the early 2 door surf/4runner came with a 22r/auto combination...the question is which auto thou? May need a toyota parts guru to confirm this for you.
G52 is a 5 speed manual not an auto
kaupoi
Post by kaupoi »
Cool guys thankyou, ill double check when I get home in the morning.
Going to fit ag tyres to her, will post a pic when its finished.
kaupoi
Post by kaupoi »
Yep, its a manual 5 speed.
kaupoi
Post by kaupoi »
Just had a look and its a 18R engine.
kaupoi
Post by kaupoi »
So Im chasing a G52 to 18r bellhousing if anybodys got one lying around??
kaupoi
Post by kaupoi »
Think its a RN105 bellhousing Im chasing?? Someone may have a better idea.
kaupoi
Post by kaupoi »
Just tracked down a 4 speed that will bolt to my engine, rapt.
j_tomo
Post by j_tomo »
Hey there ive just replaced my rn111 g52 box with a r151, it sounds like what your after, flick me a txt
0275277450
Jeremy
