hi everyone whats some mods you guys have done to your 2.8 pajeros i have a 94 swb auto pajero goes really well but seems to use heaps of gas is that normal? any info would be great please. it is reallly great around town on gas but on long trips uses abit and if you put your foot down its crazy. cheers and what boost are people running?
cheers Lee
2.8 swb pajero
Re: 2.8 swb pajero
that list of mods could go on for ever
pretty much either a snorkel or cold air into how ever u want it makes a huge difference then change the size of ur exzorst to make it flow better
depends what u really want out if pajero
peanut.901
- Bush Crasher
Re: 2.8 swb pajero
its really an allround truck i just brought 31 inch mudzillas took sway bars out and the old owner also put an electronic fuel pump in for starting and when the motor is cold it needs it to run and if left on leaks diesel but sweet once off any ideas cheap ideas?
Re: 2.8 swb pajero
Mechanical pump is rooted Lee if it needs a helper pump.
peanut.901
- Bush Crasher
Re: 2.8 swb pajero
yeah i realise that matt. only need when cold once warm runs all day with out pump
